I have been looking to purchase a lift kit for my 86 Tin top Samurai. I have been focused on Calimini. They seem to have everything in their kits that I would need such as springs,shocks.....etc. I herd a rumor the other day though that Calimini shocks ride very stiff and are not adequate for the lite Samurai's. Can anyone comment on that? My Samurai is a daily driver I'm looking for a 5 in suspension lift preferbly spring under axle (herd that is better for on road) anyone have any suggestions from which to choose trying to stay under $1,000.
If you want a smooth on-road ride get a Jeep YJ conversion. The calmini kits use short stock length springs. Any short spring is going to give you a hard ride. The calmini shocks are designed for hard offroading and a heavy rig with bumpers, cages, winches.. etc. The kit is built tough as nails but it's not designed for comfort. I have a 5" spring under axel reverse shackle lift from them. I just changed my shocks to monromatics (17 bucks/shock) and my calmini lift rides a little smoother. It's still stiff though but that's due to the short springs.
shouldnt any yj springs fit a zuk cause
Not sure what that was supposed to mean, but YJ springs are wider and longer than samurai springs. You need a shackle and hanger to accomodate the wider spring, and you need to relocate the mounts for the hanger and shackle to accomodate for the longer spring.
yeah sorry i don't know why the rest of the text didn't show up...
I was saying shouldn't they work with any reverse shackle set up?...
the cheapest way to lift i found was a shackle lift with spacer...using the original springs... that's cheap... haha
even a RS setup, if it's not made for the YJ springs will need to be adapted for the wider spring and relocated.
Extended shackle and spacer is a cheap lift, (first one I did 15 years ago was an extended shackle lift) they are unstable though and have poor handling characteristics. It will let you stuff a bigger tire under it though, and that was all I was concerned about at the time. Eventually I realized I needed a safer ride and better articulation
i've seen how they installed YJ springs in a SpOA system,is it still possible to fit the original under axle spring?and does it change the original wheelbase?if it's so,what else should be modified?thanks
