Hello,
I took apart the inside of the front knuckles. There are no seals present, number 22 in the attached schematic.
What is the part number or a link to that exact part? The felts look nearly brand new and the metal rings are good so I don't need an entire rebuild kit.
Thanks!
Here are some listings but I don't know which seal it is:
1987 SUZUKI SAMURAI Knuckle Seal
88 1988 Suzuki Samurai Steering Knuckle Seal - Steering - Timken, National, Inner, Outer - PartsGeek
I think this is the right one based on the diameter:
Timken/Axle Shaft Seal - Front (710330) | AutoZone.com
TIMKEN 710330 Seal, Front Axle Shaft | eBay
I purchased that seal 710330 from Advance Auto awhile back to replace mine. As yet I haven't done the job but I think that's the one it takes.
Just what I needed to know, thanks! ;)
I also found some info showing a National 701330 as the same part. I am going to order a pair.
