Hi to all i have a1987 samurai and i have this estrange situation related with the ignition on my cylinder # 1 if I made a partial connection between the spark plug and the wire the engine work perfect but if I connect the wire directly to the spark plug (this is the way that I most be) the engine stat to fail and doesn’t run smooth and this is only with the cylinder # one and I change the cables the ignition coil and I get the same so do you have any idea it will be much appreciated .
the spark plug are new the compresion on that cilinder is 120 punds in cool
You may have recieved a bad plug. Try that plug in another cylinder, if problem goes to that cylinder you know it;s a plug. Not uncommon with mass produced items.
Hi thanks for the replay ,I already change the sparkplug and I get the same result any other idea thanks
