Help!! I have a samurai with a 95 1.6l fuel injected tracker motor.it ran fine and I took the battery off for 2 days when I put it back on it nothing got power no headlight no dash lights absolutely no power to anything I have changer battery cables and terminals I know battery is good and I also changed the ecm please help .
Did you reconnect the fusable link to the battery, when you put it back in? Is the link blown? The main cable only supplies current direct to the starter. All other power comes from the other small cable connected to the positive battery post. Also, check the ground cables of the electrical system.
samurai with 1.6l tracker motor wont start
Yes I have done all that the only thing I havent done is change the relays out on the ecm
