1 - 9 of 9 Posts
Hello all,
I have a 87 Samurai that I have altered by swapping out the stock engine and transmission with a fuel injected 4.3 chevy vortec and auto trans. Other mods include :
Rock lobster transfer case, 6 in lift, shackles, ARB lockers and a few other mods all resting atop 32" tires.
The axles are stock and now I need to upgrade the braking system so I can stop. Going is no problem.
My question, does anyone know a shop where I can get a kit to change to change out the brakes or where I can go (in Southern Cal. area) to have this accomplished?
Thanks,
DSKPJM2S
A rear disc conversion isn't too tough. But if you want expert installations (of any kind) done on a Samurai, I suggest you go see Gary and his crew at Petroworks. He is a Samurai Master (pardon the pun) and has been doing this longer than most of us knew samurais existed...
1 (800) 952-8915
Address:
111 West Aviation Road, Fallbrook CA 92028
Tech Support:
(760) 731-9434
Gary at Petroworks sent me to Lightning Coversions in Florida, nice people, who have hooked me up with a disc conversion kit that should fix my stopping issue. It is ordered and on the way so soon I shall be able to stop without issue.
Thanks to all for the help.:p
DSKPJM2S:
If you're just upgrading the rear brakes then that isn't going to help that much. Most of the braking force is on the front end, I would do the rear disc conversion and fit the vented discs and uprated calipers from the 4dr Track/Kick, add a bigger master cylinder and a brake bias valve too to get the balance right.
off topic :
Did you make it smog legal and street driveable ???
I always have thought the 4.3 conversion would be sweet but have heard that it is really hard to get them to pass smog here in CA...
Discussion Starter #9
off topic :
Yes, it is smogged and street legal. We had to go through a ARB Smog referee but it passes no problem. Lightning who did the 4.3 install made sure it was smogged to the standards of the engine manufacture year.
1 - 9 of 9 Posts
