Replaced a new battery. Only heard 2-3 click when turning the ignition. Happen to notice the positive terminal is hot to touch. Before I replaced a new battery, I use jumper cable to connect the cable only and the Samurai starts and run. I checked all fuse and so far nothing blown out. Sure hate to turn over to my mechanic for something easy to fix. BTW I am not an electrical expert.
If the starter is clicking it is because your harness has trouble delivering proper voltage to the starter due to age and corrosion it is a very common thing in samurais. The clicky starter kits are 20.00 shipped I can set you up with a kit, PM if you are still having trouble with this. Thanks,
Mike
