Before I crawl under there and tackle this, I need to know if I remove the driveshaft off the back of the transmission. Can I slide it (trans) back far enough to remove the clutch? Got an oil leak from a plug on the back of the block that I need to repair. Maybe replace the clutch while it's apart.
GIZMO
when i did mine i could'nt slide my gear box back far enough to get it out with the clutch in but you can still get the clutch out with a bit of muckin about
