first and most important the idle seems to jump up to between 2500 and 3800 RPMs when at stop sings and when i hit the clutch to shift gears. it is not imediatly but after a secound or two it jumps up then slowly calms down to normal idle. i think it is the idle contral valve. i tryed to clean it with some carb and choke cleaner with minamal luck. any ideas or tips would be greatly apricated.
second it seems to be using or losing oil it is not beeing burnt from what i can tell and there are no prips in the grauge. it seems once every few months the check engine light comes on and i check the oil it is a quart low i add a quart and it goes off, i know it should be check more offten and i should probly keep a better eye on things.
and lastly does any one make proformance parts for the 1.8L, like high out put coils and other simple up grades.
Discussion Starter #2
not to be rude but this has been up for a while in two different parts of this forum, are there any other places that i could go to get help. i have tryed deals and shops around towm most seem to a gree with me and then tell me to bring the car to them for furter checks. i do not want to do this, i have looked for a idel control valve on the net and the few i found are like $300. i do not want to buy a $300 part and find out im not right and i do not want to take the car to a shop so they can order a $300 part and spend 20 min putting it on the car. i would just like some help please.
