1 - 9 of 9 Posts
It rides too rough for me so its time for a much younger owner,its a 92 2wd automatic with a/c p/s and p/b. 86,000 miles and originally from Florida and this winter is the first time its seen salt. It has a oil leak in the front of the motor and even though the trans had been rebuilt I could never get the lock up convertor to work and if I kept it would convert to a 5 speed,its in the Dayton Ohio area and asking 1000.00 or might trade for a larger vehicle.
Perfect for V6 or V8 swap,rust free body and frame and I need vehicles to have a better ride or I would do it.
I wish you were closer; I've got the pedals, bellhousing, trans, drive shaft, plus a 16v engine and wiring harness. I could use a clean body in Toledo.
Jeff, If you don't sell it, PM me if you could deliver. If that would work, I'm sure we would both need more information regarding transaction. Let me know. Thanks.
Discussion Starter · #6 ·
It should make it to Toledo with no problems,the trans shifts like normal but the convertor will not lock up so it acts just like a normal 3 speed automatic. I am going to keep driving it until it quits snowing and I could possibly deliver,it made it up from Florida so Toledo should be no problem.
Sounds good. Look forward to hearing from you if it doesn't sell locally.
1 - 9 of 9 Posts
