Ok i have an issue with my vehicle need some expertise on this. When vehicle has reached operating temperature it idles at 900-1000 at idle stand still no driving.
If I then put the AC on the RPM should go up to 1300 -1400 from what i've read online with the compressor engaged. but Mine puts the needle up yes then it comes down to just above 1000RPM. When the compressor cycle and disengages the RPM needle sometimes will go down decreasing past 500RPM in between 400-500 RPM now it makes the vehicle sound like it may cut off i dont get hesitation at all because when it goes passed this marker it brings itself back up to about 900 where it should be. Almost want to sound like the idle control valve is sticking IDK. But I have cleaned out the idle control valve mechanic said he doesnt like the way it is opening and closing even though he has cleaned it he said ive cleaned this with him about 4 times this year already i should buy a new one. I would like to know what other things i can check maybe TPS? i dont stall neither does vehicle vibrate or hesitate when it goes low it just sounds so because i know the sound. so attached is a video for knowledge of what i experience. I will be ordering a new idle control valve december since ive cleaned it too many times which shouldnt have to be done so often. but need to know what else to check out. the video is in the link below.
Vehicle specs
16v
1.6CC
suzuki escudo
year 1996/97
3 door
manual transmission
The electronic idle solenoid valve (ISC) (not mechanical) is supposed to raise the idle about 200 rpm or so, with the A/C on. At least on my car, you find this by following the vacuum hose that comes out of the air pipe, and goes directly to the ISC. When you close off that vacuum hose, with a pliers or similar, your idle should drop much lower than the factory idle spec, and then when you release the pliers, it should come back to about 800 rpm. I would find it somewhat unlikely that your mechanic has actually cleaned this sensor, as cleaning it is a bit fiddly. If you take the valve off the car and shake it, you shouldn’t hear it rattle (if it does, the spring inside is no longer working). Resistance across the ISC terminal should be 11-14 ohms The sensor vibrates inside - it has a plunger and spring, but there are precautions about testing this with battery voltage - the FSM advises to test it for about 1 second, and then let it rest for 10 seconds, so no continuous voltage. You are testing it to see if the plunger is vibrating inside. I don’t believe that this can be repaired - it needs to be replaced.....if this is your issue.
