pocision which is the distributor rotor current to atiemparlo.
is in the pistons in the piston one or four.
regards
Take the four spark plugs out and the valve cover off...... turn the engine clockwise until the timing mark on the pulley lines up with 0 on the gauge but be sure both valves are closed on the number one piston...... then insert the distributor so that the rotor is facing number one plug wire on the cap..... if it don't start you may have it 180 degrees out for which you would do one more complete revolution.
Joe
