My 88 Samari has a rumbling noise when I'm driving over 60 MPH. It sounds like worn tire noise, but it's not that. It started after I installed u joints. It's really noticeable in 5th gear??:confused:
When you changed the U-joints, did you phase the driveshafts correctly? Meaning, if you pulled them apart, did you slide them back together with the dots aligned? The ends need to be perfectly lined up.
