Hi. I'm looking for what the oem ring size would be for the 1.6. 2.95 bore. The machine shop can't find rings for 2 months. I don't think I need the 25 over from megazip but they list 2 ahead of that that I assume are standard size. And I'm not a mechanic. Thanks.
I'm not certain what it is you're asking here - what "size" are you asking about?
Rings come in standard size (which, in this case, is to fit a 75mm or 2.95 inch bore) & generally two "over sizes", which would be standard + 0.25mm (or 75.25mm) & standard + 0.50mm (or 75.50mm).
Generally speaking, ring size is determined by piston size, and piston size is determined by bore size - the machine shop should have measured the bores for diameter (to determine wear & ovality or out of roundness), if the bore wear is excessive, the machine shop would recommend boring oversized, which would require fitting of both oversized pistons & rings.
The machine shop would need to tell you what size rings you need to get, standard rings are available from RockAuto (see my earlier post), oversized pistons & rings are available from LowRange Off Road.
