hey people
i have a 1991 suzuki sierra and i have recently removed the origianl 1.3 litre carby motor and fitted a g16b fuel injected motor from a 1994 vitara. since i have fitted the new motor my engine light stays on. i was wondering if there is any way you can retrieve the engine trouble codes without a scanner. i ask this as i know that in commodores you can bridge 2 wires in the diagnostic plug and the the engine light flashes a certain amount of times to indicate what number code it is, can you do something like this in the suzuki's??
thanks hugely
wazza
You can do the same thing with the Zuk if you have the diagnostic connector fitted.
Diagnostics
diagnostic s
thanks rhino man much appreciated.
you wouldnt happen to know which two pins you bridge do you?
Did you check out the link?
diagnostics
hey rhino,
yeah I had a look there were I think 4 pins there,
I could probably just try bridging two at a time to see if it does anything.
I may just have to change a couple of fuses after lol.
It shows you where to fit the link on that page
