How did you "reset your idle" (it is computer & electronic sensor controlled).
And whatever you bumped, cut, moved, or otherwise disturbed in that reset process killed the A/C.
Check electrical connections and fuses first off while retracing your earlier steps.
lol I didn't cut anything. I followed some instructions I found online in a manual.
Idle Learn Procedure
Whenever the battery cables, the engine control module (ECM), or the ECM fuse is disconnected or replaced, the following idle learn procedure must be performed:
Turn the ignition ON for 5 seconds.
Turn the ignition OFF for 5 seconds.
Start the engine in park/neutral.
Allow the engine to run until the engine coolant is above 185° F (85°C ).
Turn the A/C ON for 10 seconds, if equipped.
Turn the A/C OFF for 10 seconds, if equipped.
If the vehicle is equipped with an automatic transaxle, apply the parking brake. While pressing the brake pedal, place the transaxle in D (drive).
Turn the ignition OFF. The idle learn procedure is complete.
That's exactly what I did.
