21 - 24 of 24 Posts
A search for SY413, SY416 or SY418 should find you the manual in pdf format.
check your owners handbook, you usually jack the car up, take the front wheel off and remove the inner guard panel to access the rear of the light fitting that you cant get to from under the bonnet - I've never seen a car yet you have to remove the assembly from to change a lamp. Batteries and other under body bits yeas, the whole assembly? no.
You may not have seen it, but they do exist - I own two, a Mitsubishi Pajero iO, and a Suzuki Grand Vitara - on both vehicles, the complete headlamp assembly has to be removed to change either the side/park lamp or turn signal bulbs.
21 - 24 of 24 Posts
