What is the correct bolt pattern for my 2007 Reno?
Research had got conflicting information. I'm seeing both 4 x 100 and
4 x 114.3 mentioned.
Which is correct?
Thanks guys!
A lot of wheels I see are listed as "4x100, 4x114.3" will both of these patterns fit the Reno without any modification? I can't imagine why sellers would list a wheel as being both bolt patterns.
From what I've been able to figure out is that a lot of these wheels are dual pattern or "universal" meaning they have both the patterns.
The Reno uses the 4 X 114.3 pattern--not the 4 X 100.
This way one wheel fits a lot of different cars.
So when a wheel is advertised as "4x100, 4x114.3" it literally means it fits both? Not that they are the same, it's just made to fit both?
Yep. And when you look at the center, you'll see a ring of holes all around it.
Those holes represent 2 different bolt patterns.
When you put the wheel on the car, you'll have to rotate it around until you find the 4 holes that line up.
The other 4 holes that are left are the other pattern.
