If you decide you want to try to rev past the redline limit fo the engine, I would suggest some other work done as well. Such as, shot peening and cryotreating the rods, forged pistons, knife edged crank and a full balancing of the crank, rods, pistons. The faster that engine moves the more any imbalances (however small they are) can cause problems.
So, it's not like the crank isn't strong enough to support the power of the engine, it's that the crank and other parts shouldn't be going quite that fast. I would do some research on it and see what the total rpm capability is of these engines...before revving that high.
I know on another car I used to drive, even though the redline was 8k, if you revved to 7.5 or more, the valve springs would float and move causing a need for a complete rebuild of the head....just watch out...
