Hi all. Rear engine van with F6A 12v. is it possible to remove the sump and
undo conrod bolts and remove pistons from the top?
I'm planning to fit a new cylinder head and figured if I could pull the pistons
and give the bores a deglaze and fit new rings.
Yes you can, the issue is the debris entering the bottom end and contaminating the crank and journals..
More out of curiosity than anything else, where exactly is the engine, and is this a Carry van?
All of the Carry vans I've seen had the engine in front, under the seats.
