i recently purchased a 2006 grand vitara. it didnt come with the manual nor the FOB. how do i find out if i need the remote start FOB or the regualar one. and if someone could point me into the direction to the throttle body cleaning cuz its doing that low rpm stalling thing after i replaced the battery. its the luxury grand vitara if that help...
So you just don't have any remotes? But you have almost for sure keyless entry module installed (build in BCM). If you need remote start, install it with door lock option. Any car alarm shop will do it. It is really easy to do it in our Grand Vitaras. All needed wires are in driver kick panel.
If you think you have remote start installed already, you should have antenna glued to the windshield. Or if it is add-on remote start, try 3 times lock the doors using lock switch in door panel.
