Hi everyone. Newbie here. I've got a 3 door 2004 Grand Vitara which I've owned since new. To date the vehicle has been super reliable, it even runs the original clutch. Being Down Under, the vehicle is right hand drive. I have a minor electrical issue with the indicators. The rear passenger side indicator lamp no longer has any voltage, so I'm assuming that the wiring loom has some sort of break between that point and the front side guard indicator globe, which is working fine. The drivers side indicators globes all work perfectly. What I'm wondering is how do you remove the wiring loom on the passenger side of the vehicle so as to inspect it and discover where the break in the cable is? Or do you guys suggest simply running another cable to the rear connector which I believe can be found where the tyre jack is? How would a person go about doing that (like where is the easiest point to begin and end that replacement wire?) Dunno, but I'd appreciate any advice. Chris
