Has anyone put coil over shocks on the rear of their tracker and if so where did you get them and do you have a part number...Also can anyone tell me where I can get adjustable rear upper control arms
It's going to take quite a bit more than just a part number - the upper shock mounts were not designed to support the weight of the vehicle, you're going to have to custom fabricate replacements, and I also expect you'll need to custom fabricate lower mounts for the axle.
if 2nd gen rear suspension is like 1st gen, ( i think it is), then shock is way too close to wheel/axle/brake plate to do that, no room to fit a spring.
