1 - 8 of 8 Posts
2009 SX4 with J20A motor.
Driving in traffic up a long steep hill the engine began to rattle and the oil light flickered a bit and came on.
ASAP pulled off to a flat car park and checked oil - half way between the two marks.
Topped up anyway and rested the car.
On restart, little bit of momentary rattle then disappeared. no oil light.
Abandoned intended trip and headed back home.
Rattle reappeared but engine behaving well otherwise. oil light flickered a bit and came on for short periods and then off again. Rattle though was consistent - no louder or softer and didn't disappear with or without oil light being on.
Stopped and left idling and lifted the bonnet. Suspected overhead gear rattle possibly due to oil starvation. However, rattle seems to be from behind the engine in the area of the alternator/power steering pump. To be sure lifted oil cap on off and rattle sound didn't change at all (ie: if overhead rattle I expected to hear a increase in volume and/or a tone change, but no difference at all).
Decided safe to continue home gently.
Temp okay.
Oil light disappeared up hills, came on downhills and flickered around undecided on the flat.
Stumped.
Are these engines prone sensitive to oil filters like the early Toyota engines used to be? ie: doesn't like an aftermarket oil filter)
Could the oil filter have collapsed internally?
I assume they don't have an external oil pump that may be rattling.
Could the oil pickup in the sump have come loose?
Anyone had a similar experience or know if this is a previously known condition or fault of these engines?
*I'm beginning to suspect the rattle is timing chain due to low oil pressure, although the rattle doesn't change when the oil light is out or on. There's plenty of oil in the sump, so am inclined to change the oil filter and hope for an improvement. If not, I suspect the oil pump may have partially failed or the oil pickup tube is loose. Looked under the car and no damage to sump or anything like that.
What is the mileage of the car? Did you buy it new ?
Purchased used at 105,000 kilometres two years ago and now done 136,000 klms.
I've done more research on the J20A motor on google images and thinking the hydraulic tensioner has popped out. Loose chain plus low oil pressure. More likely than a faulty oil filter.
Before you do anything else, how about you connect an oil pressure gauge and see confirm that the pressure is actually low.
Typically, if there is an oil pressure issue, there will be a pattern to it, and you have reported a pattern that suggests that the oil pickup screen may be partially blocked - BUT - with the oil level half way between the marks, the entire pickup should be submerged - so it is still worth the time & trouble to confirm.
Is the J20 engine sensitive to oil filter quality - to some extent yes - personally I will prefer to only use a genuine Suzuki filter, so I keep them on hand, but if I had to, I would not hesitate to use a good quality filter - say Purolator, which is what I use on my other vehicles - I would say as long as the filter has an anti-drain back valve, you can use it.
Good idea.
Where exactly is the oil sender unit please. Or a connection for oil pressure perhaps.
I did fill the sump back up to the full mark but it made no difference.
I'm sort of convinced now the rattle is timing chain, but not sure why as yet. Oil filter, tensioner, broken guide (but that doesn't explain the oil light).
I did see some reference in researching that the tensioner has some sort of valve behind it (a washer with a hole perhaps) that has been known to break. So maybe the tensioner isn't popped out but gushing excessive oil and not applying pressure perhaps???
Can the timing case be removed with engine in the car? ie: worked on through wheel well?
Does sump have to come off? It looks like the sump can come off in the car - no crossmember in the way. But thats only a cursory look and not up on the jackstands.
The oil pressure sender is under the exhaust manifold.
... as long as the filter has an anti-drain back valve, ....
Good point...but is this a conspicuous specification that one can find on the filter box?...I'll pay attention on my next visit to Canadian TIre and read all the boxes..just for fun..
Myself and others near me , several years ago, have seriously experienced FRAM filters and have at that time noticed a non negligible oil pressure drop compared to other makes. Just to say all filters are not born equal.......
Where ever you buy your filters from, they should have an application guide from the manufacturer of whatever brand(s) of filters they carry - you can look up your vehicle and engine and they will list a filter that is based on the vehicle manufacturer's specification - you will find the information on anti-drain back valves there.
I don't know how common it is your neck of the woods, but I have seen many people here who will use a filter based solely on the mounting dimensions, many of them use an L10028 filter for everything they work on - this, by the way will fit your J20, but is not the appropriate filter, as it does not have an anti drain back valve.
Why is this anti drain back valve critical? It prevents the oil in the galleries from draining back through the filter into the pan when the engine is off, it allows oil to reach the overhead cam and hydraulic lifters faster on a cold start, it allows pressure to build faster in the lifters and the hydraulic tensioners in the timing chain system. Why are there filters without it? Because overhead valve engines with pushrods didn't need them.
One last thing - if you know what you're looking for, you can, without reading the box or the guide, by simply eyeballing the filter, determine if it has the valve or not.
1 - 8 of 8 Posts
