my radio tunes in ok, and is ok if switched off by off button. problem is it looses its memory when the ignition is turned off. help please
Sounds like a simple wiring fault. The connector at the back has a trickle feed from the battery to retain memory - is it connected? Can be a bigger problem on most radios as this fault can also disable them so that you would have to enter the security code each time - assuming you have the code?
Beancounter
Hi Beancounter.you were spot on. loose connection behind the radio. much obliged. thank you very much .Dumbo
