Hello,
I am Brian from Vietnam, I would like to DIY Radar brake support on my car SUZUKI VITARA LY 2016 1.6AT.
But I do not know how to do:
  • What are the parts need to buy?
  • How to install?
Please help me.
Thanks in advace!
What's a radar brake support?
Reactions: Brianvn
Ahhh, ok, i misunderstood your original post. Not something you can fit easily as it is a factory designed option and requires significant components and the correct engine ECM, ABS, BCM & TCM modules and firmware
If it wasn't fitted at the factory I believe it will be exorbitantly expensive to try and fit as an aftermarket option.
Reactions: Brianvn
Thanks,
I understand that this option is hard to do, but I still want to try
I need to find the parts first, from that I will study how to DIY.
You need to find the radar transmission and receiver, the engine ecm, body control module the abs module and possibly the transmission control module along with any associated wiring etc, then there's the factory programming and setup that's required
Just the modules alone would be several thousand dollars even if you could find second hand ones.
It would be cheaper to sell the car you have and buy one with it fitted.
Reactions: Brianvn
Thanks for your advise. We cannot buy the car with this option in our market now because the car did not imported from 2017. If I import by myself price will be very high
