propeller shaft won't slide back in. I replaced the front seal on the transfer case and like a idiot I didn't make an alignment mark the sidekick belongs to my ex so please help
The shaft should not be indexed, but check the splines, if you have a spline wider than the rest that is the index.. there will be a corresponding index in the housing/output shaft..
There's actually two places where it looks like it's an extra wide tooth but I looked on the shaft inside the trans transfer case and couldn't find anything and it won't line up on it
