I have a 1987 Samurai just replace the clutch and flywheel seemed to be running fine and then I towed it up hunting and now having problems grinding when shifting and it seems to be in 4lo but the front end is unlocked and in 2hi. When in 3rd or 4th gear I can only go 20mph, any ideas.
check the oil in your difs, t-case, and tranny. If there's any particulate matter (little shinny flakes of glittery metal) then you probably dammaged it while towing. always disconnect the rear drive shaft when towing and make sure your front hubs are unlocked.
