Just got a 88 Samurai and it has some play in the shifter. I took the shifter out to figure out what the problem is and when I put it back together it wont go into any gear now, It's like all it has is neutral. I must have missed something. Any advice would be great. Thanks
Pull the shifter back out and look down into the shift tower. the shift forks need to be lined up in the center. use a large flat tip screwdriver to move the rods into place. THEN put the shifter back into place. if it is still really sloppy , then you may have to replace the original bushing (called a shifter sheet) and maybe even the locator bolt that slides into the slot in the shifter.
Do a search here on the site and you will find quite a few threads talking about the same thing. It is a common problem for our zooks.
This question answered by both Billjohn and Alternator while sharing a meal in El Paso! Yes... he made the trip to El Paso!
Yup, I made it to El Paso, all the way from Saudi Arabia.
I had that problem before, and I wasn't really able to do anything with the shifter tower neck on, so I had to remove the neck to get a clear view of the forks. Just in case you find it difficult to see what you're doing with the neck on.
I had my mechanic friend come over and do it for me. I had to give up. Thanks for the advice guys, appreciate it!
