Got an 88 Sammy, and i an needing to replace the Pressure switch, does any one know were this is under the hood?
Thanks Guys!
Which pressure switch would you be looking for? If you're looking for the oil pressure sender, it'll be be on the left (drivers side) front side of the block, right next to the oil filter.
Sorry, I can't help you on that one, Mine doesn't has AC. It should be near the drier though. It will have two wires going to it, and it should be in the high pressure-side line coming from the compressor. Good luck.
