I know this is not what you asked, but I'll point it out, for those who may, at some point, consider it - fog lights and spot lights are VERY different things - they look alike, they both illuminate the area in front of the vehicle, but they do so in different ways, and if they are good quality units (not all are), they are designed to do different tasks.
Fog is essentially water, tiny droplets of moisture, suspended in the air, the light from your headlights is reflected off of these droplets, back to your eyes and can dazzle you - to reduce this probability, fog lights are designed to have a wide beam with a sharp horizontal cut off, ideally they will be mounted low down which is why you'll usually find them below the bumper level. Mount them higher up, closer to the driver's eyelevel and you increase the probability of the light being reflected back into the driver's eyes.
Spot lights come in different styles with different beam patterns, spot beams, driving beams, they are designed to reach further than your headlight high beams, and if mounted too close to the ground, the beams will hit the ground rather than be projected into the distance to do the job they are designed to do.
Fog/spot lights are an area where quality makes a huge difference, I've seen paired fog/spot lamps (both in the same housing) that were nothing more than H3 bulbs behind lenses (yellow for the fog, white for the spot) with no attempt at any sort of reflector. With the advent of white LEDs, the market has been flooded with "cheap Chinese" LED lights, with the manufacturers making all sorts of claims. Any LED fog light that has the LEDs visible behind a flat polycarbonate "lens" is not a fog light, it's a "flood" light, because it lacks the horizontal cut off that fog lights need to have.
Spend your money wisely, rather than a fancy LED, look at the "name brand" products, Hella, Cibie.
