I must replace the rear wheel bearings on my 1988 Samurai.
What parts do I need beside the wheel bearings and are the bearings the type that slide out or are they pressed in?
:confused:
You need the new bearings and retainer rings. they should come together in a set. Rear wheel bearings are pressed on to the axle shafts. Once you pull the shafts you will need to use a press to remove and replace the retainer rings. Removal can be done by cutting off the bearing and ring with a cutoff saw, but be very careful not to nick the shaft. Cut 3/4 through and use a hammer and chisel to 'pop' the last quarter apart. You will still need a press to reassemble.
It is worth doing the seals at the same time. Get a seal driver or go to your local muffler shop and get a matching size piece of scrap pipe and make your own for free.
