Im having an issue on my 2008 sx4... washer jets worked fine, then didn't, found break in hose, fixed it, still no flow. getting solid pump noise for rear washer fluid but no noise for front jets. Are there seperate pumps for the front and rear washer jets? anyone else had this problem? could there be anything other than the pump causing this? couldn't find find a fuse labeled washer fluid pump or anything similar...
WHere do you live? Can cold be a factor?
Of course, 2 pumps, as said in adjacent thread you looked at first. WILl look at shop manual and post whatever is availalble
I found a small check valve in my 93 sidekick washer hose. The only thing I can figure is to pump washer fluid that far they put a check valve in so it stays full and doesn't drain back to the tank.
No idea if yours has a check valve inline but it may be something to look for.
