Factory service manuals don't have any recommendations on honing, or break-in, although I believe break-in is covered in the owner's manual (which I don't have) - if you want my personal recommendations, I would bore very slightly undersized and then hone to the required dimensions, honing gives a better surface finish and a cross hatch pattern that supposedly holds oil and improves the break-in.
Manufacturer's break-in is usually nothing more that a warning to limit speeds for the first thousand miles or so, and not to allow the engine to lug, my preference is to limit engine rpm and load for the first few hundred miles, and to raise the rpm limit gradually, brief higher rpm runs are permitted and in fact encouraged, as long as they are not sustained or repeated.
Accelerating briskly through the lower gears allows the combustion pressures to "load" the rings against the wall, helping them to seat.
Don't forget to retorque the head bolts at the first service.
Question for you - is this a re-bore (oversize piston & rings) or a re-ring job - my suggestion on honing does not work for a re-ring job, but, if you're not boring, honing is even more important because it breaks the glaze on the cylinder walls, and so allows the new rings to seat properly - the issue becomes how much can you hone without developing excessive clearance.
