Can anybody offer any help/opinions on how to set the pinion angles on my tracker, since installing my Calmini lift I've been having a little humming noise/vibration coming from the rear pinion an anything over 90km/h , the kit comes with an adjustable heim joint to adjust the rear pinion angle but i am not sure on where to start and how to find the proper pinion angle for my tracker.Here are 2 pictures showing the angle coming out of the tcase and the angle at the diff.
Kris
Ideally the angles should be equal at both ends - the old eyeball says you have more at the transfer case end, so try screwing the heim in some to rotate the axle nose downwards...
Mark
Did you mark the yoke and drive shaft when you took it apart ?
Try moving the drive shaft one bolt hole .
I have the same lift and have no problems with the driveline.
I would ay if you were going to straighten the angle , you should lift the front of the diff, but having said that, I don't think that's your problem. Are those the same tires/wheels you ran before the lift ?
Been there when re-powering my old Chevy Pickup...
An off-set (diff pinion nose down angle) between 1 (min) to 3 (max) degrees is the optimum spec. Also make sure that your vehicle is loaded as it would be for normal ride height (fuel, some representative cargo, winch or other add-ons included) for a most exacting calculation.
Drive Shaft Harmonics
