Under this law, all gasoline will be mixed with 10% ethanol. Gasoline with ethanol is reportedly bad for carbureted engines and most especially F5 and F6 engines which are not designed to run on ethanol-gasoline mix.
How will we cope with this?
Bad news :(
Can you give us insight on how can it harm our carbureted Every? I hope theres workaround to make our Every run this fuel.
no. we can still use leaded gasolines without the biofuels. this is applicable only to NEW vehicles who are capable of handling E10 fuel...second, i doubt it if will be fully implemented because people will rally against it like we carry/every owners are.
jsix, i think the F6A is not designed to run on leaded gas
in another forum, it was suggested to replace all fuel lines and recalibrate the carb for our ride to run on E10
e5 muna gagawin nila bago mag e10 napanood ko sa isang tv station ung
tongkol sa biofuel noon..
sa amerika nga e85 ung gustong gawin nila para maging independent sa
gasolina na galing sa ibang bansa
