Hi guys,
I changed the serpentine belt 1 month ago. After 2 weeks, I started hearing a noise. I thought it was because of the belt, I went back to the shop, asked them to reajust it.
Now, each time I accelerate, I can still hear the little vibration for 1-2 seconds, especially at low speed, but the noise seems different from before. Do you have any ideas what this is about, please?
Check to see if any exhaust heat shields are loose and vibrating. ;)
Thank you Max,
I was worried because i did not understand.
I will try to fix it myselef. :)
If i don't succeed i will wait until i will go for oil change at the shop.
Thank you again
I also suspect a lose heat shield. Rather than just remove it, you can secure it with band clamps. I just did this with one of ours.
