1 - 20 of 29 Posts
Parting out a 1991 Suzuki Sidekick. 4Dr. 5spd. 4wd. 178k. 8V.. Missing timing belt, accesory belts, and a couple pulleys. Looks like someone went in to fix it and gave up, everything else looks complete.
New PICTURES of a few major parts. Can get a picture of anything you need.
Apple .Mac
Tell me what you guys need off of it and we'll work something out. No reasonable offer refused, I am not wanting to sit on these forever, would like to get rid of them rather quickly.
Here are a few prices of some of the major components. I have EVERYTHING off this though so if there is anything else you need let me know.
Wiring Harness- $100
ECU - $50
Front axle housing and diff - $100
5.38 Geared 3rd members - $75/each
Front axle housing - $25
Rear axle housing - $25
Rear axle shafts with bearings and good brake shoes - $65/each
Front cv shafts - $50/each
Rear driveshaft - $50
Front driveshaft - $35
5spd trans - $200
Transfercase - $100
Tierod and tirerod ends, secondary mount and pitman arm - $25
Power steering hoses - $15
Power steering resovoir - $15
Manual locking hubs - $25/each
Multifunction Switch - $50
Grille - $35
Side view mirrors (power) - $35/each
Gauge cluster - $50
Radiator - $55
Starter - $30
A/C Compressor - $75
Alternator - $50
Doors (complete)(4) - $100/each
Tailgate door (complete) - $100
Flywheel - $40
Clutch - $40
Pressure plate - $40
Rear axle bracket with ball joint - $45
Exhaust header and cat - $35
Dash - $60
Motor - SOLD
Steering parts (steering box, pitman arm, pump, pump to engine mounting bracket) - SOLD
Discussion Starter #11
junior24 said:
where are you located, and does this have a tach, and if it does, will this work in my 92 Tracker????
I am in NC. Yes it does have a tach. I have no idea if it will work in your 92 Tracker.
was the vehicle 4x4 by any chance? if it was do you still have the transfer case? theres the part that the speedometer cable sticks in i need the piece that goes into the case itself
this might be a long shot but do u know if the headers would fit a forenza
Discussion Starter #16
Yes it was 4x4 and yes I have the Xfer case but I am not parting it out, selling it whole.
1 - 20 of 29 Posts
