Hello, I'm new to this forum, and own a 2004 Verona EX which has been a great vehicle, no problems! I've just noticed a very minor cosmetic flaw, and will require a close inspection on your part. Has anyone noticed slight peeling of paint below the fuel filler door? It is actually at the interface / seam where the rear fender meets the polyurethane bumper just below the fuel door? I suspect that spilled gasoline has collected in the seam and caused some paint to bubble / flake. Problem is easily solved with a toothpick to remove loose paint, and a small dose of touch-up paint.
The paint on the trim piece that fits around the outside door handle is peeling. It's about half the way around the handle so far. Also had a small rock bounce off off the hood and took quite a bit of paint with it. Touched up the hood with the touchup paint from Suzuki, haven't done the door handle yet.
[email protected]
