Update for whom cares
Today I installed two of the four O2 sensors and it wasn't too bad. I had fewer issues with the plastic clips that Max reference because they are located on top of the engine near the firewall and easy to unplug. Getting to the sensors was not so bad on the passenger side, on the drivers side it's much tighter (which is why I stopped with two). The layout of the inline six is different than the pics Max put up. The way they are positioned in relation to the manifold and catalytic converted, lead me to guess the bank 1 sensors are on the passenger side because they appear before the CC (which you can't actually see because of a heat sheild). I will snap some pictures later this week and put them up. Anyway, I had the codes scanned and the P0031 is indeed gone.
However, more codes have surfaced so the engine light was back on within the hour. I have ordered the evaporator emission control system valve from the dealer (a $50 part) and will be replacing that soon. My bigger problem is that dreaded wheel sensor problem that has my ABS light on. This is something I will need the dealer to handle because I can't even figure out where they are :huh:
