Hi everyone!
I have a 2010 SX4 crossover auto with 144k miles I just replaced my water pump, radiator, reservoir, temp sensor with all the gasket. I changed all those because the water pump is leaking so might as well change all of them since it's high mileage.
After I changed all those parts now my car temp gauge always went up to high when i m driving in highway with heater on or off. But when I drive stop and go traffic in the city the temp gauge go back to middle. Does anyone knows what's wrong with my car? I check nothing leaks, radiator fan turn work just fine and the coolant level is normal. Please help thanks!!
Does your heater work flawlessly...giving regular heat when you ask for it. WHile your profile/signature is inexistant, it seems you are from the USA, hence engine is J20B. Fill up your signature/profile with all details about car and location. Specially trim.... auto or manual HVAC ?
Hi,
Before I change the water pump, radiator the heater doesn't work. Now the heater work perfectly. Yes, I m located on USA Northeast so outside temp currently around 5-6 Celcius. My HVAC is manual NOT automatic. I drove to work today and if I drive above 50 mph the temp gauge went above normal. Once I drive in a stop and go traffic it goes back to normal level in the middle. Thanks for your fast reply.
have you changed the thermostat and if so, is it a good quality 82C one? with bleed hole to the top?
I don't know, I use the OEM ones as I find most of the aftermarket ones are not that well calibrated and can stick.
