hiii !! i'm from Indonesia!!! u uust bought new SJ 410 and i have problem with overheating in my machine. please help me
Try the obvious. I'd replace the thermostat. Are you losing water? If so check all the hoses if you dont find a leak may be the head gasket.
Have you tried servicing the Radiator?
Are you still using the original "pully driven fan" or using a electrical fan?
If still using the original, do you have the fan shroud installed? It helps to focus on the air flow. Most "second" Jimny/Katana here in Jakarta doesn't.
If using an Electrical Fan, is it spinning fast enough? Could be a bad fan motor.
Jimny/Katana in Indonesia as I found usually have this problem.
