1 - 11 of 11 Posts
USA 2012 Grand Vitara AT 4WD 2.4L I4 F DOHC 16V
Daughter's GV dumped all coolant today and promptly overheated and quit running. Waited for it to cool, refilled, and it does turn over but not start. It is spraying coolant from the top rear center of the engine. I suspect a catastrophic valve cover or head gasket failure. Anything else in that area that would leak?
Compression check first, then start diagnosis from there, im betting head gasket, or more likely a cracked head. If its got any Compression I'll be surprised Had one lose a bottom radiator tank and it got shut down immediately but even that was too late.
Found the source of the leak. Busted hose on the back side of the engine. Dead center at the top. She tried real hard to fire but just won't. Sounds like lack of compression.
Discussion Starter · #4 ·
Are you familiar with a particular compression test kit that works well with this engine? I'm familiar with the spark plug location and concerned that a standard kit may not work with this design.
My compression tester has about an 8" flexible hose that screws into the spark plug hole. Most should work if they reach the plug hole
Remember gas pedal flat to the floor, that cuts fuel, and pull the ign fuse in the main box under the hood to stop coil drives.
Font Parallel Number Screenshot Data transfer cable
Something like this should work - $20 on Amazon - no, I haven't tried it, I have an Equus set that seems to have been discontinued.
Mines like that but a different brand
Discussion Starter · #8 ·
Thanks, picked up a kit today. Will probably test it tomorrow.
Discussion Starter · #9 ·
70, 35, 60, 75 on the compression. 1 and 4 were dry, 2 and 3 were full of coolant. Working on getting the head off next.
1 and 4 are still concerning, unless gaskets blown between the adjacent cylinders. Definitely check head for warpage, I bet its moved a fair way.
Discussion Starter · #11 ·
1 Looked like it may have been wet, the top of the piston was shiny. Was hard to tell on 4. Won't know until I get it apart.
1 - 11 of 11 Posts
