So I'm driving home today and Sammy is doing ok. Hit the turn signal and the engine starts to stutter. Goes away when turn signal off. Then turn on lights and bam engine starts stuttering bad. Turn them off and goes away. So had the alternator checked and have an intermittent issue with volt reg. So does this sound like a reason that it would stutter when lights are on. Or do I have something else going on. Also seem to be having problems getting her started. Even when I just shut it off and try to restart it has issues. Thanks in advance.
Is it only with the turn signals or is it happening with any other electronics. If its just the turn signals then it could be something as simple as a short or bad wiring. It sounds like it is taking too much power.
