Planning to change the oil pan because the plug thread is shot.
Have ordered a new pan and gasket, fel pro os30765.
The holes in the gasket don’t match the new pan.
Does the 04-08 Forenza have a gasket between the pan and the block?
Is this gasket for another location?
depending on motor model it may or may not have a gasket, use a good quality pan sealer, these are designed for the job. Permatex grey will do at a pinch. Let it set 24 hrs before adding oil and starting so it doesn't wash it off while wet and get it into the oil system.
