Could any one of you expert tell me where is the SX4 oil filter located. please and thanks in advance
Robert
crawl up under the passanger side tire area of the car from the front, and look straight up in the gap where you exhaust pipe goes into the engine bay. its a straight shot up from the O2 sensor and wire that stick into the pipe.
Thank you for you information and I found it this morning and I think is rather easy to dislounge it from there, Thanks again..... by the way I am using a vacuum oil changer to extract the used oil from the engine, so the drain plug stay there as is
Thanks again
just make sure, when changing the filter out, to cover the O2 sensor with foil or something because the oil will drip right onto it and the wires, and it may cause a problem somewhere down the road.
