I have a 2000-2001 GV 2.5. Went to change the oil today and the drain plug would just spin wouldnt tighten or loosen. Does this mean a new oil pan?
For a lasting and proper fix, yes. New or good / used.
There are some self-tapping oversize (aftermarket repair plugs) out there. At least there use to be. Also a rubber expanding plug of some sort comes to mind. But you still have to remove the plug you have, first off. Google it.
Is it the drain plug that is stripped or the metal bung / flange around it turning, as in some pan designs? I can't recall the exact design on our pans. If this style, you MAY be able to weld the bung to keep it from turning, but it may leak at the joint. :(
im not sure which is striped. last oil change went fine no probs but not this time. Im guessing removal/installation of a new pan requires removal of the axle or motor?
Wow,good luck removing the oil pan,not an easy job !!!
The bug was pressure fit on many of the vehicles, a good couple of tacks with a mig/tig will secure then enough to remove the drain plug....
..... Philip
