2009 OEM Clarion 7-speaker setup
having troubles with my ASWC-1 communicating with the wheel buttons after pioneer 2din install
i'm supposed to connect to the vehicle's pin 19 but just want to double-check the connection is proper as i'm not having any luck
all the diagrams i see only are pre-2008 which doesn't correspond to what i see in-person
there you go. hopefully this helps, my 2015 matches this diagram
thanks a million!
ok either i'm reading it with the wrong orientation or there's conflicting info
Pin 19 according to Suzuki is Purple
Pin 20 according to Suzuki is Pink/Black
if I remember correctly (will double check tomorrow)
Pin 20 in my vehicle is Black (as evident in the Metra's instruction to connect it to chassis ground)
Pin 19 in my vehicle is Grey/Green
the plot thickens
Purple and pink black are steering wheel controls look for those in the main loom plug, multimeter across them on ohms range will return a value, press any button and value will change. Don't go by pin numbers.
I suspect you are reading the pin numbers in the wrong orientation. Multimeter is best method.
