My 2008 swift has failed etest on code number P0340 which is camshaft position sensor A circuit bank 1 or single sensor , is this simply a need to replace the sensor or is it likely to be an underlying problem ??
Advice, help, assistance welcome please !!
Thank you
Thanks Dudleydo, great information, bit to technical for me, but I will probably just change the sensor. Is it easy to get at ? Also, what is vvt ?
Updated the diagram to show the non VVT engine CMP.
VVT is "Variable Valve Timing"
I'm not familiar with the Swift engines so can't comment how easy they are to get at, but look quite accessible in the diagram.
