hi to all
i have a 89 samurai and i replaced all the bearings in the gearbox and the t case and a new clutch set when iam driving at 4th gear there is a noise and the noise appears only when i remove my leg off the gas
and if i put my t case on neutral and drive on the 4th gear the sound gets louder could it be the u joint or what
thanks
noise in 4th gear
I have the same problem and i wonder why no one else has replied. Have you came to any conclusions?
check the u joints and grease the shaft you see the fittings on it....also motor mounts and tranny mount.and the oil in the rear diff and the transfer case.
voltage variance chg sysem/fusebox
sorry, wrong place
