signals were working fine then nothing.
wipers went on for a second then died and got stuck halfway on the window.
any suggestions?
I would start by taking it apart, check all the pigtails for proper connection, check the ground make sure the screw didnt rattle out. See if its getting power to the swith.
good chance that you have a loose or corroded connection in your steering column. Check the multi switches in the turn signal and the wiper controler, check the wire loom and connector for loose or shorted contacts.
grounded right
Check all the grounds or the individual lights.
Check the plug in the steering column, under the bezel, near the dash.
Check the mounting of the wipers on the windshield.
Have you checked the fuses ?
IF it ever works it should work again.
If it stops and never starts again that is trouble. (read replace)
But sounds more like a ground (earth) issue.
You may be able to attach 12 volts to the wire to the wipers to bypass the switch...that will tell u if they will operate at all.
You can feed 12 volts to the individual lights to check them...if they light it is at or near the switch.
